I have noticed that on some competitors rotator options, there is the ability to set a ZERO position on the rotator. The ZERO position is more like a home position and not the actual camera angle. So like if you have an EFW attached you could rotate your train to a position that insured it would not run into other objects. You should be able to get to any desired angle by rotating the camera in 90 degrees in either direction.
