This problem continues to happen. I have the new Asi 2600mc Air and it periodically hangs when trying to download to memory. This is not a cable issue .
Also the wifi connection is unstable and disconnects often and station mode does not work. I am
using the latest firmware release. I am suppling 12V from the AM5 mount so wondering if this might be a power issue. Also the camera downloads to a USB stick on the camera so I am wondering if this could be an issue? My other 2600mc pro with my Asi air pro does not do this nor do I have any wifi issues.
I also use AM5 power port to power everything and it works fine.
The download issue happens during AUTORUN sequence.
The wifi instability is quite bothersome. The AM5 wifi is NOT used there is no wifi interference and I am only 10 feet from the camera when this happens.
Dennis
