Is there a standalone utility that will read the internal temperature on the ASI174MM? I know it can be done with an application like Firecapture, but I don't want to use that software since all of my imaging is done with Sequence Generator Pro (which unfortunately doesn't appear to log the camera temperature or any other of the driver settings such as gain or offset).
I guess what I really want to know is can you read the camera temperature (or the other settings) using the ASCOM driver?
