Does the protective window block light at the infra red wavelength?
km The protective window of ASI174MM is AR coating, won't block IR
@Tech@ZWO - Is there an advantage to using an IR-Cut with the 174MM Mini when the camera is used as a guide camera?
dane It may be helpful when the seeing is bad.
