Hi,
I need some help trying to connect to the SeeStar from my PC. The SeeStar is setup in station mode and the PC and router both can see the SeeStar on the network. When I try to map a network drive both using \seestar or using \192.168.0.138 (the IP of the SeeStar. I get an error. Below is a screenshot of the error and showing I am using the correct IP, the SeeStar is on the network, and my PC can see the open ports.
I have also tried use a different account using the name of the seestar S50_7e6a3597 pw 12345678
