I don't think so. You can make a copy of a plan and modify it, for example remove the portions that worked and keep only the ones you want. One feature I would like to see would be the ability to move things around, swap their order, etc. You can sort of do that now by changing the start and stop times but it's cumbersome. It would be nice if you could move things around without having to edit them.
