I have an Asiair Pro that I use with a Canon EOS R and Az-Gti. After the latest firmware update (2.3(11.56)) I'm having a problem that doesn't allow me to shoot. Using Autorun, with any shot duration of lights, after the first shots, camera stop shooting and on asiair still present "Idle", or "shooting". The command is not sent to the camera (using the manual shutter button the camera shoots, therefore it is not blocked). Then after a few minutes without shooting and without touching anything, another real shot is taken and then you have to wait many minutes between one and the subsequent. The problem occurs both with and without tracking (I raised the Guide Stability settings to the maximum in order to avoid stability settle time holding). I've already tried restarting but I can't fix the problem... Has this happened to anyone else? Does anyone know what the problem could be or is it a bug?
Here one of the logs, it's just an example, I have some others similar:
Log enabled at 2025/02/02 19:08:08
2025/02/02 19:08:08 [Autorun|Begin] M 42 Start
2025/02/02 19:08:08 Target RA:5h41m31s DEC:-1°57'24"
2025/02/02 19:08:08 Shooting 120 light frames, exposure 120.0s Bin1
2025/02/02 19:08:08 Exposure 120.0s image 1#
2025/02/02 19:10:16 Exposure 120.0s image 2#
2025/02/02 19:12:25 Target RA:5h41m30s DEC:-1°56'37"
2025/02/02 19:12:25 Exposure 120.0s image 3#
2025/02/02 19:14:33 Exposure 120.0s image 4#
2025/02/02 19:24:48 [Guide] Dither
2025/02/02 19:24:48 [Guide] Dither Settle
2025/02/02 19:25:18 [Guide] Settle Timeout
2025/02/02 19:25:18 Exposure 120.0s image 5#
2025/02/02 19:32:47 Exposure 120.0s image 6#
2025/02/02 19:41:38 [Guide] Guide star lost
2025/02/02 19:41:40 [Guide] ReSelect Guide star
2025/02/02 19:41:40 [Guide] Start Guiding
2025/02/02 19:43:16 Exposure 120.0s image 7#
2025/02/02 19:46:05 Stop Autorun Manually
    albyz85 Hello. Please check your SD card space first and try to switch the SD card to see if the problem can be solved. If your ASIAIR does not shut down after the problem occurs, you can send us the error log and we will find the cause based on the error log. Thank you.
    The problem was due to the USB drive used to save images, I replaced it and everything is back to normal, thanks everyone!
    Write a Reply...
