I love my ASIAIR, but it lacks the ability to trigger actions for things like closing my ROR, turning on my flat panel, or anything else that is not attached to the scope. However, if I could control the timing of one of the power ports changing from 0 to 12VDC I could easily connect that to a relay connected to an ESP32 or other wifi microcontroller and use that change to trigger another action. For instance, if at power up I could set one port to go to 12V it could automatically open my roof, remain at 12V (with super low current draw if any at all) during my session, and then use the Plan mode to turn that output port off at the end of the session which would close my roof.
Seems easy enough to me and would be a feature that could be used in innumerable ways.
Thanks
Tom
10 days later
Upvote this! It would be really useful for to be able to set a configuration for each power port in autorun and plan mode.
Write a Reply...
