Brand new ASAIR controller and ASI2600MC Duo camera, both purchased in January. The Camera is the only accessory that I intend to power from the ASAIR. First time out, the camera turned on for a few seconds then shut off (the fan stopped). My main power source is a Deep Cycle Marine Pb/acid 12V battery. It also powers my mount, Celestron CGX-L. It delivers 12V, 10 amp (fused) max.
Since that first set-up and failure I've tried multiple ways to get the controller to power my camera. The only way I can do this is to plug a separate 12V power supply into the camera. The ASAIR App recognizes both my camera and mount now, but I haven't tried controlling either.
I used a voltmeter to test the power out ports on the ASAIR. All four ports deliver zero volts when the controller is booted up and running. Is there a fix for this?
