I have just installed ASIStudio 1.14 on a Linux PC and when I run ASICap I'm only getting 11 fps from my ASI120MC-S camera when running at 1920x960 resolution and RAW8 capture. When I reduce the frame size to 640x480 then I get around 60 fps. The PC has USB 3 and when I run AstroDMx Capture on the same machine I get 29 fps at 1920x960 resolution with the same camera.
For comparison I have an older, and much less powerful, laptop ( with USB 2 ) running ASIStudio 1.9.3 / ASICap 2.9.3 and I get the expected 30 fps at 1920x960.
Can you comment on what the problem might be?
