I know that you can't use two ZWO cameras over the ASCOM interface, but can you use the ASI120MM in the latest v2.5dev7 release of PhD while imaging simultaneously with the ASI174MM using the ASCOM interface in Sequence Generator Pro? I select the “ZWO ASI Camera” item in the PhD profile (i.e. I don’t use the ASCOM setting).
I seem to be having some problems with this combination that I think might be related to trying to use the two cameras at the same time (one to guide, the other to image).
Has anyone done this (using two cameras as above) and is it officially supposed to work? I have the cameras connected to separate USB ports on my notebook computer running Windows 8.1 using the latest release of the ZWO software (downloaded and installed on Nov. 6, 2015).
Also, there seems to be no way to check or set the USB transfer rate ("traffic") using the driver setting in PhD. Basically, once you select the camera in PhD v2.5dev7 you can't do anything except connect to the camera. Does PhD just default to a recommended USB traffic setting for the ASI120MM? I think in general the traffic rate is supposed to be kept below 80%.
