Hi,
I love the Seestar, and mine is one year old this month. I have a problem that has started occuring recently. When I power up, I usually tell it to Open Arm. Then, I perform the Adjust Level calibration.
After this, if I go to Sky Atlas and choose a target to image, the scope won't move. It tells me it is "finding object", but the arm does not go anywhere. Then it tries to identify the object, but can't (of course).
I try several Goto's on other objects, but the arm doesn't move. I have found a workaround. I use the Close Arm command. Then if I use Sky Atlas, the telescope moves properly and performs a Goto.
I wanted you to know about this, both to help other users, and to see if you can troubleshoot it for a future release.
With Kindest Regards,
Joseph Mello
