I have the same issue. I'm imaging high up in the sky and no matter what I do the ASIAIR insists on re-doing the calibration at the start of a plan. I tried adding two targets in the plan, hoping that the guide calibration from the first target (which was in a good position for calibration) would set a proper guide calibration. When the second target started it redid the entire calibration again. Doesn't matter if auto restore calibration is enabled, or auto guiding disabled in the plan settings. Would be great to just have a setting to either stop doing that, or make it smart enough to determine that the target is not in a great spot for calibration. When doing a manual calibration it even says that it's a bad position for guide calibration, but when running in automatic mode during a plan it seems to just ignore that completely.
