Andrew Ferguson It is normal that the WLAN list shows that the network cannot be accessed, because Seestar's WiFi is only for data transmission between the user's Seestar and the device, and cannot access the Internet, so there will be this prompt, which does not affect the control of Seestar.
If you want to connect to Seestar's WiFi and at the same time have access to the Internet, you can do it in the following two ways
1 Set up mobile data or cellular network on your cell phone.
2 If you are at home, you can bridge Seestar WiFi to your home network via station mode in Seestar app, after successful bridging, you can control Seestar directly by connecting to your home network and at the same time you can surf the internet. Here is the link to the tutorial https://h5.seestar.com/course/79218
