Until today, I have always been able to connect to an ASIAIR device from my S24 ultra and control it from its application installed on my S24 ultra.
Now, I can connect to ASIAIR WIFI.
My problem is that since Yesterday if I connect without problem to the wifi network of the ASIAIR, on the other hand once the software is launched, it cannot communicate with the ASIAIR that it cannot find.
I have performed the following tests:
using the software on a Samsung tablet allows the connection and everything works fine
connecting to Wifi from the S24 ultra is possible (as previously stated) and the S24 responds from a PC connected to the same network.
In fact, the problem is limited to the communication between the S24 ultra and the ASIAIR from the application.
I have uninstalled and reinstalled the application as well as restarted the S24 without result.
An update to Android 14 took place just before the Problem appair
Any help or suggestion will be welcome
Thanks in advance.
