You can improve stability by making sure the S50 tilts toward a leg, rather than in between two. You can also try to shorten the opposite two legs slightly, which will make it even more stable, but then the wedge tilt will no longer match your latitude. At 40 degrees latitude you should be OK, but for even lower latitudes these extra steps can help.
