Deuero83 I moved the mount to the Home Position in the SynScan Pro app.
Did you 1) disconnect the mount from ASIAIR, 2) reboot (power off and then on) the mount, and 3) reconnect to ASIAIR after you used SynScan to move the mount?
If not, that (moving the mount with SynScan) is most likely to be your problem.
That motion by an external device (be it manually, or by using SynScan) is not known by ASIAIR (the ZWO devices are made to be simple, and they only work if you do exactly what it wants, and not what you want).
ASIAIR establishes the position of the mount (sync) right when it connects to the mount.
It then assumes the position from then on is relative to the command that it gives to the mount. Any external movement can cause ASIAIR to think that it was still located at the location is last knew about. So, disconnecting and reconnecting the mount after it has been repositioned back to the home position will resynchronize the mount.
You might be able to get things to work if you perform a manual sync. I.e., do a plate solve and then ask the mount to move and sync. If it is very far off, just do a couple of plate solves. The problem is that this will not work every time -- e.g., if the ASIAIR has also lost the pier side of the OTA. I have monitored the USB commands from ASIAIR to my mount, and have never seen ASIAIR query the pier side, which is critical to know with German Mounts; ASIAIR just make wild assed assumptions.
