I am writing to ask if there is a firmware update that will prevent an ASI120MM USB2 camera from disconnecting when using Ekos/Indi packaged with StellarmateOS. I'm running StellarmateOS on a couple of RPI 5 units in a remote mode situation (Parenthetically, I'm using StellarmateOS rather than my ASIAir as, ironically, ASIAir does not support it's own family member the ASI120MM). When using Ekos/INDI, the camera is found & initialized. It appears to accept commands. However if I try to capture an image (In guiding mode), it will almost always, disconnect from Ekos along with any other ASI camera (in this case an ASI183MC) operating in Ekos at the same time. I don't appear to have this disconnect issue with any other ASI camera including the ASI120MM mini and ASI2600Duo; only when using the ASI120MM. I've tried to run the camera without the ASI183 connected with the same disconnection results. From my internet research, I understand that there may be a firmware update available to overcome this problem.
