It is normal that the WLAN list shows that the network cannot be accessed, because Seestar's WiFi is only for data transmission between the user's Seestar and the device, and cannot access the Internet, so there will be this prompt, which does not affect the control of Seestar.
Seestar's Bluetooth is only used for activation and assisted authentication in the app, it can't be paired in the phone's Bluetooth settings, Seestar only supports controlling via WiFi. If you want to connect to Seestar's WiFi and at the same time can access the Internet, you can realize it through the following two ways
1 Set up mobile data or cellular network on your cell phone.
2 If you are at home, you can bridge Seestar WiFi to your home network via station mode in Seestar app, after successful bridging, you can control Seestar directly by connecting to your home network and at the same time you can surf the internet. Here is the link to the tutorial https://h5.seestar.com/course/79218
