I have been having problems with my AM5N in the alt azimuth mode. When I press home the mount moves to point north and then moves the scope to the west. If I then try to go to a target it is well over 90 degrees of, if I move the scope back to point north before going to the target I still see the same problem. If I use the handset to move to the target the software will not allow me to sync as it is more than 5 degrees moved. I do not see these problems in equitorial mode.
I have reached out to ZWO twice but have not received a response. Any assistance would be greatly appreciated.
