I was unable to obtain focus.
Filter Wheel has M54 thread and is directly connected to ASI2600MM Duo.
Sigma 24-70mm F2.8 DG OS HSM | A
Per above recommendation, I have tried the following to obtain 55mm backfocus:
Filter Wheel = 20mm
Nikon F-mount adapter = 12.5mm
Spacer between Filter Wheel and lens adapter = 5mm
ASI2600MM Duo backfocus is 17.5mmm
Total back focus = 55mm ⇒ focus could not be obtained
Using the instructions provided in the documentation that came with ASI2600MM Duo:
Filter Wheel = 20mm
Total back focus = 50mm ⇒ focus could not be obtained
Note: This appeared to be the closest to focus
Other spacers tried:
Spacer between Filter Wheel and lens adapter = 4mm
Total back focus = 54mm ⇒ focus could not be obtained
Spacer between Filter Wheel and lens adapter = 9mm
Total back focus = 59mm ⇒ focus could not be obtained
Spacer between Filter Wheel and lens adapter = 16.5mm
Total back focus = 66.5mm ⇒ focus could not be obtained
Spacer between Filter Wheel and lens adapter = 21mm
Total back focus = 71mm ⇒ focus could not be obtained
Spacer between Filter Wheel and lens adapter = 37.5mm
Total back focus = 87.5mm ⇒ focus could not be obtained
None of the above combinations worked. Please advise next steps
