henkiepenkie2 the Seestar is basically seen as an external storage device from your PC's point of view. The files you deleted are in the unit's "recycle bin". Reconnect the S50 to your PC, right click on the drive, go to properties, push the disc cleanup button and you will see the "hidden" recycle bin. Clean it up and you are done!
