I reviewed many of the camera postings in the forum, seeking advice and possible other recommendations.
I've tried all of the suggestions: driver, Ascom drivers, Ascom Platform, cables, ports, computers and still device is not found.
This is standalone single camera connection directly to the USB-C or USB-A port.
Usually when you plug and unplug a device there is a system sound, and the "Device Manager" will reset with every insertion or extraction. So its totally unrecognized.
Attempted to use ASICap, PHD2, SGP, Fire Capture and SharpCap - none of them will connect to the ASI174 mini, but I also have a ASI220 mini and ASI120 mini as my control units (make sure I did not break something with all the changes); and they all respond and operate as expected. Same cables, ports and operating system.
When I plug the ASI174 Mini using the cable off the ASI533MM hubs USB-A port - its recognized and able to run in camera mode or guide camera mode.
What is different from ASIair-->USB-A compared to PC-->USB-A/C?
What is unique about the ASI174 mini? I'm unable to update the firmware as the tool does not recognize the hardware.
OS = W11 Q4H2 updates (x2), MAC= Sierra (x2).
Suggestions welcomed and very appreciated.
