With v2.4 I have a problem with the Auto Focus (AF). I started by using the Framing mode in the Alt/Az mode. After moving the target to center it in the Framing Mode FOV I used GoTo to center the telescope on the desired position. Once the telescope successfully centered on the desired position I started the AF, and, the guiding stopped!! I know it stopped because the stars started drifting across the FOV displayed on my laptop. By the time the AF was complete and the guiding started again, the FOV was no longer centered on the original position.
Am I doing something wrong, or, is this a problem?
Steve
