Having just tested out v2.4 for the first time tonight, I find the new location feature to be interfering with plan execution.
Steps to reproduce for me (happened on two different phones, with two different S50s).
- Start a plan while next to the seestar (station mode).
- Go to some other location in the house.
- From the home screen, click the plan. It says "Require Location Permission", "Seestar app needs your location to update weather, perform accurate GoTo, .......". Note that the app already has permissions to get location, and it was already used when starting the plan.
- Click "Go Settings" (which should probably read "Go to settings"). It then says "Cannot Choose Location", "To Change the location, you need to stop the image enhancement first."
- Go to the stargazing screen and click stop. It then says "Operation Prohibited", "An ongoing plan is in progress. Please stop the plan first.".
So... Because I walked >30 feet away from my seestar, I can't actually look at plan details anymore, nor stop the plan.
Home screen while plan running:
Trying to click on the plan:
Telling it to go to settings:
Trying to stop from the stargazing tab (note the ugly streaks from tree branches, and the reason I wanted to stop in the first place):
If I connect with another device (tablet) that has no GPS capability, I can look at the plan and stop it. If I do stop it, the home screen on the original device will show an address that isn't my own. It thinks I've moved to my neighbors house. When I was standing next to my seestar, it had my own address showing.
There should be no need to check the location when clicking on the plan button and a plan is currently running.
