Hi
Perhaps it is a silly question but I would appreciate some guidance. During the meridian flip, the telescope is rotated and while reaching the original target the image is upside down as a result of the flip (basically rotated by 180 deg). Correct? If the flip occurs during an autorun routine of the ASIAIR plus, let's say after recording 15 frames out of 30, should the after-flip 15 frames be re-aligned with the before-flip 15 prior to stacking? or it is automatically done by the asiair?
thanks in advance
sandro
