Hello. I have had my 174mm-mini for several years, it it a great camera. When I use it in an OAG, the extension tube comes off. When I use it in a guidescope, the extension tube comes off. The problem I am having is the black ring, that the protective window is glued too, is very loose and keeps coming off, leaving the sensor exposed. I thought of dipping a small amount of threadlocker on it, but I am sure what chemicals will impact the adjacent senor.
Does anyone have some method to make that ring stick on the camera better? Thanks for the help-
