What is the S50 vertical center? It is mentioned in EQ Mode tutorial.
Thomas
Simply put, the vertical center setting ensures that the telescope moves smoothly along the vertical axis when tracking, which helps maintain smooth target tracking. If you need more detailed setting instructions, you can check the tutorial link in the Seestar app https://h5.seestar.com/course/167308
Thanx, an other question: where can I order the SeeStar S50 mount for adjusting the device according latitude and north direction? Thomas
