On the first occasion using the Seestar it went to the sun and gave me some wonderful pictures, on the second time few days later it can not find sun , all level and calibrated
Check the positioning accuracy and compass calibration, and check whether there is any magnetic interference. This is a tutorial on how to find the sun manually. I hope it will be helpful to you.https://h5.seestar.com/course/79044
I assume that you can only image the sun in Alt-Az mode. Is that correct? I suppose if you don’t move the mount that is still polar aligned from the night before, finding the sun in EQ mode is possible. The same for the moon during the day or night. Gordon
@color block jam If the mount remains in the same position from the previous night and is still polar aligned, it simplifies locating celestial objects.
