After capturing an object and the final view is present, you can denoise it, adjust brightness/contrast/saturation. At that point you can download it, Export it, or Moments or Community (no idea what those 2 do). Would be great if it also saved the resultant file on the Seestar. Even better would be if it recorded the settings for brightnesss/contrast/saturation
