I appear to have the exact same issue and I have opened a ticket, specifically regarding the fact that EQ Polar alignment fails on what appears to be the second attempt at plate solving. I used seestar alp and saw that the api scope_get_equ_coord returns what appears to be an incorrect DEC value (negated value of my actual latitude). I too had EQ mode working initially, then I switched back to Alt/AZ for a bit. Upon attempting to switch back to EQ mode the polar Alignment failed as described and I then noticed the the "Close" arm button issue (no idea if related).
ZWO placed one append into my ticket which provided no information on the problem.
ZWO support , could you please add a comment to my ticket BT20250417634127S. I'd like to understand current status even if the root cause is still unknown.
Thank you
