I’ve not been able to achieve custom framing since EQ mode went live. My EQ alignment is set to a reasonable tolerance, eg.~ 0.3/0.4 or similar. I can set the framing in the Atlas (with EQ grid displayed), then GOTO, then when LIVE stacking starts, it’s back to the standard sensor orientation and size. When I go back to the Atlas, my framing choice is still shown in gray box outline, with the red and blue boxes set back to standard orientation. When framing with the S50, it often ignores framing the first time, but then honors my selection after the second or third attempt. The S30 no longer honors it regardless of number of attempts.
