I've read inconsistent reports online. Does this cam have an AR window or UV/IR cut window? Thanks.
The ASI2400MC Pro comes with a UV/IR Cut window by default — not just an AR-coated protective window. That means you do not need to add a separate UV/IR cut filter when using this camera with standard imaging setups, including refractors.
