since the AS120 version was introduced, a number of users reported vertical banding in processed imaged, especially when using high gains.
the problem was typically addressed by applying darks to the images. This solution however does not always work since the banding pattern changes each time the camera is reset, or a change in the gain settings is applied.
Another, more efficient solution it to wobble the planet within the FOV during image acquisition.
This can be done using the mounts hand paddle for instance.
No darks required. It takes car of all the vertical lines after the stacking is done. Voila!
Doris Thibeault
