I don't understand..... You mean for cooling 120mc? Firecapture has sensor temperature as option but If a camera has not an active cooling control system you can't manage the cooling, if you decide to cool 120mc as i posted you the delta T ( temperature difference ) is more or less 10-15 C° below ambient. With that cooling system with a 30W peltier (2.5A), eq6 i use a 17Ah power thank. If you want you can add a controller to the peltier so you can choose how much Watts get to the peltier
Inviato dal mio GT-I9301I utilizzando Tapatalk
