I have two ASIAIR+/CAA setups. One is a couple year old 64gb ASIAIR+ and the other is a new 256GB model, along with two CAA. Both controlled with a tmobile tablet. Neither will remember that is has a CAA attached. When I start up ASIair, the CAA is greyed out and says NONE. I click on the selection box and choose the CAA. It recognizes it, reads its serial# and firmware version. Once selected, I can control it fine. However, when I reboot or powercycle the ASIAIR, the CAA is greyed out again and I have to select it again. Everything else is recognized and remembered (Duo camera, AM5, and an EAF plugged into the same powered USB3 hub with the CAA), but not the CAA. I have to set it up each time. Running latest v2.3.1 code. Any suggestions?
