Hi Everybody.
I recently bought a second ZWO camera ASI6200MM that now run with the ASI220M used as guider.
I try to manage all the equipment under Linux. Everything was file as long as there was only one ZWO camera.
With two, the "indi_asi_ccd" driver get completely messed.
I then tried to switch to the single camera driver "indi_asi_single_ccd".
I configured the $HOME/.indi./ZWOCameras.xml file. Updated the /usr/share/indi/indi_asi.xml as well.
Created two symbolic links for two separate driver names indi_asi_single_ccd_1 and indi_asi_single_ccd_2
But it's still not working. When the two cameras are connected, INDI can't see them simultaneoously and keep
identify theml with a generic "ZWO camera" name.
I started to look at the driver. There is a mention to an INDIDEV environment variable.
I start to be a little discouraged
Any experience from users with similar setup?
