Thanks! I knew the ASIAir normally would support this, but I wasn't sure if having the built-in guide chip and seeing a secondary guider to choose from would present a problem at all.
Can this camera and guider be controlled by another device, even if the built-in ASIAir is functional? What if the built-in ASIAir breaks down? I wouldn't be surprised if partially broken would be a problem, but what if your friend borrows your camera and wants to use it with his other-brand setup? This is potentially a real scenario I am likely to run into.
