I am trying to use custom objects in Plan mode to create a series of images of the same star, but off set around the sensor frame. The plan will consist of 9 images. I then combine the images into a single fits file that is fed into SkyWave which is an application designed to collimate a Ritchey Chretien telescope. The 9 images are defocused by a specific amount as needed by SkyWave. My questions are:
1) How do you edit or delete a custom object and/or custom catalog?
When running a Plan the ASIAIR tries to do a plate solve no matter the mount setting which I consider to be a bug.
2) Can that be fixed?
Thanks for your consideration
