riklaunim wrote:WinJUPOS can combine RGB image with mono luminance channel as well as align images and fix planet rotation. So you can use two cameras for planets.
I would suggest an eyepiece turret or flip mirror to mount two cameras and just switch between them at will. Orange or red visual filter on the mono camera for clear luminance (or brighter if you use ADC).
I think he wants to try without any filters or other accessories, just a 120mc and 120mm.
I have a mono ordered but have not used one before. Could he simply shoot a set of colors with the 120mc, replace with 120mm and shoot a set of black and white as L channel?
The one shot image will have RGB channels, he can add the L channel from 120mm to the RGB during processing. I have no idea what will that look like, but worth the try.
