Since ZWO added the EQ mode for the Seastar but did not develop a mount or wedge for it, users are left searching for a wedge to polar align their device. However, this new mode has introduced a couple of issues. For those using the Skywatcher Adventurer wedge for polar alignment, the process can be quite frustrating. Some may not agree with this perspective, but here’s why it can be problematic:
When we successfully set the Seastar to our current altitude and the device begins capturing images, it prompts us to fine-tune the alignment by displaying arrows corresponding to the altitude and azimuth screws. We need to adjust these screws to the lowest numbers, ideally around zero, to receive a checkmark. However, achieving that checkmark is the real challenge.
The Skywatcher wedge poses difficulties due to its small altitude adjuster and the tiny piece that secures it—both of which can be easily lost and do not reflect light like a typical screw. When adjusting the altitude, it’s crucial to be careful not to over-rotate, as doing so can result in a higher number, potentially unscrewing the knob from the wedge. Conversely, if we rotate the knob backward to decrease the numbers, we encounter a problem when we reach zero on the wedge; at this point, we cannot rotate it any further down. This forces us to rotate it upward again, which can lead to increased numbers that we want to avoid.
I would like to propose two new features for the Seastar's polar alignment:
Pure Polar Alignment: This feature would be similar to the normal polar alignment but would display lower numbers and add a limit that doesn't allow it to go past 50° degrees, which could be helpful for users who struggle with the current process.
Remember Last Successful Polar Alignment: This feature would enable the Seastar to automatically align itself, enhancing its functionality as a smart telescope.
I believe that these additions would significantly improve the user experience. Does anyone else agree? @support@Seestar
