After years of success with my ASIAIR Plus and my AM5 I'm unable to image. The corruption sequence begins with a message that the EAF needs to be manually applied. This is followed by the EAF, main camera (e.g., 2600mm) and EFW all being disconnected. This sequence of failure also keeps showing a WiFi disconnect message (I'm using a direct Ethernet connection). Here's what I've tried: 1.) Changed my 12v 5 amp power supplies to 12v 10 amp supplies (interestingly, I couldn't use both 10 amp supplies, the only configuration that worked was the 10 amp to the AM5 and the 5 amp to the 2600mm, 2.) I changed all my cables. 3.) updated firmware.
FYI: I was shooting in Plan Mode
The above has all been repeated for the last three nights!
I'm tempted to just purchase a new ASIAIR....is this the only answer
