Hi. S30 is a great product. Here are some suggestion to make it a little easier.
I am using it in a city so most of the sky is partially blocked by buildings. From my apartment, I have only the southern sky. It would be easier if the "Best Tonight" section adds direction (e.g. S, SE, N ) information beside the altitude. It is because often after I select an object, and the S30 rotates to the object which is blocked by a building. It becomes disappointing after the wait.
Second, the atlas in the seestar app displays object of interest. When I tap on an object, it shows "IC414" for example. I do not know what is IC414 but I know I am interest to see Galaxy instead of the many star clusters. It would be better if it can add name, if there is no name, add the object type such as Galaxy, Star Cluster etc. Even better to have a filter for Galaxy or Nebulae etc. Please also add an info link beside the name so that user can know more and decide if he is interested in that object and if he is, he can tap the Goto button.
Thank you very much!
regards
