The last 2 times I tried to capture images the S30 failed to find ANYTHING! I rebooted, disconnected iPad, reconnected etc. spent hours trying different targets. Object failed. I tried different parts of the sky. Is there a known issue? Thank you.
What target do you want to GOTO? Is there any obstruction above your lens? Have you completed the horizontal adjustment and compass calibration normally? If it is deep sky shooting, is the preview image in focus? It depends on your operation. The reason why the target cannot be found is uncertain.
There is now more problems than ever since the recent updates.
Every time I press go to the app freezes . Very very frustrating.
Check your initial focus value. First window of S50 configurations, Focus->Current POS. Manually focus on a star and then use that focus value as the Current POS value.
