Hi Sam,
I'm thinking about getting the ASI 174 monochrome to use as a guide camera for my QSI 532. I see the backfocus for the ASI 174 is 17.5mm which means I would need the 5mm spacer for the QSI. Do you have a low profile adapter for the ASI 174 that would allow the camera to reach backfocus at 12.5mm with c-mount female threads?
Thanks,
Ron Stanley
What do you want to connect to ASI174? It has T-thread (and optional C-mount adapter).
I was wondering if there was a lower profile adapter for the front of the camera to make the backfocus 12.5mm, but looking at the size of the chip it is probably too big for the prism in my OAG. I think the prism is only around 15mm diameter.
yes, you can use the camera cover of other low profile camera such like ASI120 or 224
but there is no protect window
