I’ve connected my Losmandy G11 Gemini 2 mount to the ASIAIR using a USB-B to USB-A cable. However, ASIAIR does not recognize the mount.
Can anyone advise which connection type I should select in the ASIAIR mount settings? Is there a specific driver or configuration required for Gemini 2 compatibility?
Thank you in advance for your help!
Ari
Ari Observatory
