I am using SkyWave software to collimate my Ritchey Chretien telescope. In order to do that I need to run a Plan that takes a series of images of different custom objects. The software requires that the telescope be de-focused by a specific amount. The problem is that when you run a Plan it ALWAYS attempts to do a plate solve which ALWAYS fails because the scope is out of focus. There is a toggle to turn off Plate Solve under the mount, but it is not honored when running a Plan. I request that a toggle be added to the Plan Mode to turn off Plate Solve. Thank you.
