In the software program N.I.N.A. the CAA rotator is properly connected but when I am in the framing window an try to set the rotation angle I cannot see anywhere to test if the rotator is moving to the preset angle, unless I do it in the equipment -rotator window with Move mechanical position. How can I move the rotator to the position angle set b in the framing assistant? Does N.I.N.A know what angle the rotator is at?
