Hi
I have just updated to 2.5. I was using Scenery mode for a while. After I finished, I powered-off the S50 from the app, but the arm did not close/return to its home position, and stayed open.
When I restarted the S50, it seemed to think the arm was closed, even thought it was open. Opening the arm made it open even more…pointing directly up.
I powered down again from the app and it closed correctly.
I repeated this again and the same thing happened. Arm stayed open after power down.
I repeated it a third time and it powered down correctly.
So, my conclusion is there is an intermittent issue with the arm returning to its home position after power down.
Best regards
Tony
