So here is what I did and the results.
I did not use a barlow, I did use a moon filter. I recorded using FireCapture for 60 seconds.
FireCapture v2.4 Settings
Camera=ZWO ASI224MC
Filter=L
Profile=Moon
Filename=Moon_193901.ser
Date=181215
Start=193901.092
Mid=193931.613
End=194002.135
Start(UT)=013901.092
Mid(UT)=013931.613
End(UT)=014002.135
Duration=61.043s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT -6h
Frames captured=3967
File type=SER
Binning=no
ROI=1296x960
ROI(Offset)=0x0
FPS (avg.)=64
Shutter=1.000ms
Gain=200
AutoExposure=off
HighSpeed=off
WBlue=95
SoftwareGain=10 (off)
WRed=52
USBTraffic=100
Brightness=1
HardwareBin=off
Gamma=50
Histogramm(min)=0
Histogramm(max)=255
Histogramm=100%
Noise(avg.deviation)=n/a
Limit=none
Sensor temperature=16.8 °C
I opened the .ser file using Autostakkert2 and followed the steps 1 & 2. To get step 3 to be enabled, I clicked on the 'Place AP Grid' button. Then I saved the image as a TIF.
I opened the TIF file in Registax and on the Wavelet tab I clicked Do All and saved the image as a BMP.
This is the result:
Not sure if the Wavelet did anything at all. I just used all the defaults in the operations. No great features selected in the shot but I guess it came out okay.
Any suggestions for next time?
